Hello,
Is there any way to “downgrade” the file size?
I only want the orbit view but my project is 130mb
thanks
Hello,
thanks
In general, the main way to reducing the scene size is optimizing the geometry (by removing some objects or replacing them with low-poly alternatives) and decreasing the number of lightmaps (by using lower global lightmap resolution in the Bake tab or using Custom lightmap resolution for some large objects like terrain, surrounding buildings).
If you shared the link to the scene with us, we could give you more precise advice for this particular scene.
Thanks.
Since this is a 3D scan there is no easy way to reduce size by optimizing geometry. However, there are two ways how you could improve loading time:
Based on browser developer tools, doing these two things brings the download size down to ~10MB from ~60MB.
