hello,
i have a question about the orienation of the sun. is it possible to change it. i want to "rotate " of 180 degree the orientation. thank you in advance for your help
hello,
Are you using SketchUp for 3D modelling? If so, then the best way to orient the Sun is to do it in SketchUp using the Shadows tray: Casting Real-World Shadows | SketchUp Help . Then, when you export the SketchUp model with the Include sun option enabled, your SketchUp sun position will be exported.
i use SketchUp. i try it asap. thank you for your answer
