Hi, Everybody? how are you?
I’m a new user of this Shapespark.
I have an issue with Baking.
It takes so much time to get the Super Samples.
But Post-process took less time than Baking.
Once baking in the Low quality, then Post-process has applied again in Super Samples, can it be said to same in the result?
The Samples setting impacts the baking phase, but not the post-processing phase. It is the number of rays traced for each lightmap pixel. The higher the number, the less noisy the scene is, leading to higher quality. Using higher number of samples for post-processing is not equivalent to baking with higher number of samples.
