When I apply the material to be changed it only appears the color and not the texture it should!
in the texture pool everything appears correct.
How can I solve the problem?
Objects on which you apply the textures need to have some texture applied in a 3D modeling program, otherwise UV mapping will be missing for these objects and the replaced textures will not be mapped correctly. From your screen it looks like in the 3D modeling program you had a blue furniture. You can use a blue texture instead of a scalar blue color to fix this issue.
Solved the problem, thanks for the tip
