Hi everyone,
I try to learn more about instancing cause we do a lot of space with 30+ chair, lamp, desk, ( sometimes plants )
At first I was enough with the following exemple :
__lounge_chair_red__0
__lounge_chair_red__01
__lounge_chair_red__02
Since in Shapespark in instance count it semmed working
Lately I improve a lot with JavaScript and API of Shapespark and try to have the most control of everything
At first I notice something fun :
For instance work and detected with my scene I don’t need following the following name convention :
So I guess the fact it was mandatory was because my lack of English when I read about those topics
Other funny things when you follow this convention you can somehow trick Shapespark count
Even with completly not instancied different object,
I dig a bit and find the scene.json when you load a scene
Here I find the definitive information if instance really effective or not ( because we can have a missinformation in the software of Shapespark )
But anyway it’s not so important all that story to ask my questiont :
Cause when I instance by exemple a plant I try to instance leaf, then plant, so a plant can have a lot of object
If I do instancing of course finally it’s not so much even for 100 x plants
But the object count in Shapespark definitively increasing …
My question is more about knowledge, how it impact performance ?
Is it impacting ? Or is it false positive cause i use instance ?
If I duplicate a mesh composed by many mesh I can avoid this object increasing but
According what I learn it’s bad to make instance from 3D software for export from a multi mesh mesh ( for some software it make group but I’m on Maya it create a new mesh )
But somehow in scene.json it look ok the subpart ( so all meshes from the combine mesh ) are well instancied
Maybe lucky or maybe I just was wrong about the fact to instance every mesh separatly then instance a group of those mesh )
It’s working too but create a lot of little mesh and increase object count
What is really the perfect way to do an instance for performance ?
And if I instance a multiple x100 mesh group this object count increasy is right or fake because I use instance ?
Do you know in scene.json or any other place where I can have the info to look myself this object count information and analyse the result myself ?
and is for a plant instance leaf, then tree is the good way ? or just a mesh with the tree ? but i lost a lot of instanced leaf for the parent tree against the price of object count …
thanks a lot
