Whats up guys!
Why is this happening in my scene:
I have some wood panels on the wall, and two of them are diferent after the bake and pos processing. Am I missing something here?
Thanks in advance!
Whats up guys!
Thanks in advance!
It looks as if light probes cause this. Maybe overlapping or not included areas. Did you test to re-arrange them? Or to delete them to see if this will change anything?
Hola @Anthoni, esto me ha pasado algunas ocasiones cuando el volumen del lightprobe no cubre la totalidad del espacio o cuando tengo dos lightprobe en un mismo espacio y se cruzan o sobreponen sus volúmenes, ya revisaste eso?
Thank you guys for the help.
@tim, if I delete it, then the panels will not have reflections, right?
@jorgearq, I have 2 light probes, 1 in this main space and the other inside the half bathroom on the left.
After not being able to find a resonable solution, I will just turn the panels matte, anyway.
Thank you again!
@Anthoni, there is a bug in the light probe to object assignment and your issue seems to be caused by this exact bug. We’ve already fixed the bug and the fix will be included in the next release of Shapespark.
