Same name but not same tour!
Greetings to all
One of the techniques I use to set the same parameters between similar tours is to pass the elements inside the folder from one tour to another and then update the scene with the new textures from Sketchup, this allows the recorded views, camera parameters, textures and others to be used. I haven’t had any major problems with this technique, but today this happened to me:
why 2
why 3
why
I’ve checked what I can and I don’t know why this is happening!
The technique that you use is recommended for sharing settings between scenes. Did you save and upload the scene after changing the title? When I now go to https://all360.shapespark.com/ttp_upgrade_v1/ I see correct title (ttp_upgrade_v1).
Now it is good! I had to upload the tour several times so that the names were coordinated, thanks @jan.
