when trying to upload the scene, I am getting the following error : scene upload null.
I’m not using any audio extension, only video texture extension.
Could you send a problem report from the Shapespark application main window ‘Help & Support’ tab? The logs attached to such report would help us investigate the problem.
Thank you for sending the report. In this case there is a problem with the error reporting that is not showing a correct error message. The actual error that should be displayed is: the scene contains too large video file. The video size limit is 100 MB
To fix this error, could you replace a video texture that uses such large video file with some smaller file?
The just released version fixes the error reporting, so a proper message should be shown instead of the scene upload null.
