Can i use my model as commercial use ? Like create a retail walkthrough and for commercial use ?
Sure, Shapespark is commonly used for commercial purposes. The only exception is the trial version - the trial is intended for evaluation.
There is a separate issue of third-party assets used within your 3D model, you should check which one allow commercial use, but this is independent from Shapespark.
mean that once we bought the packages then the modelling can be commercial used right ?
Yes, it can be commercially used.
Hi, What is the meaning of above this one ? I don’t get it. Third party assets used within my 3D model.
If, for example, you use a 3D model of a sofa created by some other person or a company, you should check if a license of such model allows for commercial use.
