Shapespark 2.5.3 is out with the following changes:
- Multi-material edition. The Material tab now allows to select multiple materials and edit properties of all the selected materials at once.
- Revit exporter improvements and fixes:
- Strip numbers that Revit adds automatically to linked model names. Now, if a model is linked a few times in a project, all links use the same name in Shapespark.
- Fix an imported CAD model being rendered black when the Mirror transformation is used on the model.
- Fix failing export if a Revit project contains a model group without any exportable elements.
- Use WebGL2 on iOS devices. Viewer on iOS device can now leverage centroid sampling to reduce lightmap aliasing artifacts. WebGL2 had already been used by other platforms.
- Fix double-clicking in the editor viewport not navigating to the clicked point. The double-click navigation was broken in the previous release.
- Expose global variables corresponding to URL hash viewer options. The global variables can be modified from custom JavasScript code (for example placed in a
body-end.html):- WALK.FLIP_MOUSE corresponds to #flipmouse,
- WALK.AUTO_PLAY corresponds to #autoplay,
- WALK.HIDE_PLAY corresponds to #hideplay,
- WALK.SHOW_HELP_ON_LOAD corresponds to #help,
- WALK.GAZE_IN_POINTER_LOCK corresponds to #gazeinpointerlock,
- WALK.NO_GAZE_TELEPORT corresponds to #nogazeteleport,
- WALK.VR_LO corresponds to #vrlo,
- WALK.VR_HI corresponds to #vrhi,
- WALK.MOBILE_HI corresponds to #mobilehi.
