When I create a view and put a sprite rectangle as a trigger to open a URL, this rectangle automatically rotates following the avatar’s movement. I would like it to be stationary on the y-axis. It is possible?
The only way to achieve this is to use Object type trigger (an object prepared in your 3d model)
Could this be an improvement for the next versions?
Could this be fixed by javascript?
It is not possible to change this behavior with javascript and we don’t have plans to introduce such an option, objects triggers are the only way to achieve text triggers that do not rotate to camera.
