Otros programas se han acercado a esta necesidad tomando una imagen que aparece inmediatamente en una ventana emergente y permitiendo anotaciones sobre ella, automáticamente se guarda la imagen con la nota y se genera un trigger con un sĂmbolo de nota que se guarda al cerrar el recorrido. Luego si tu u otra persona vuelve al mismo punto y toca el trigger de nota, te salta la ventana emergente con la informaciĂłn que a su ves puedes editar.
Se podrá hacer algo similar?
Saludos
Jorge
Is there any way to annotate within shapespark and then another user can log in and review those notes?
How to annotate
How to save those notes
How to link them to a specific point
How to upload them for yourself or anyone else to see them later
How to modify that note
Other programs have approached this need by taking an image that appears immediately in a pop-up window and allowing annotations on it, automatically saving the image with the note and generating a trigger with a note symbol that is saved when you close the tour. Then if you or another person returns to the same point and touches the note trigger, the pop-up window appears with the information that you can edit.
The notes are visible to all the meeting participants. They are also kept until a meeting is deleted, so if you reenter the same meeting link the notes will be still there and you will be able to respond to them.
It is likely because of your custom onNodeTypeClicked handler, that captures clicks in objects and prevents note placement from receiving information about these clicks:
