SuperBake time issue
Hi guys,
Previously It take to 6 hours for the super bake, now it takes 12 hours.
Please give me some solution for this.
My laptop specifications:-
ROG STRIX
Intel(R) Core™ i7-9750H CPU @ 2.60GHz
RAM:-16GB
STORAGE:-256SSD+1TB HDD
NVIDIA GeForce GTX 1660 Ti GDDR6 @ 6GB 192 bits
Hi, this is probably caused by ‘light tree’ feature, which can increase baking time (on average by about 25%) but also increase the rendering quality for the same number of samples.
In some scenes which we tested, bakes with light-tree had a similar quality to bakes without light-tree with 3x the number of samples.
With light-tree you should be able to achieve very good quality results with much smaller number of samples. If you previously used 1200 samples, you can try 600.
If the results won’t be satisfactory, the you can simply disable light-tree on the bake tab.
In general, if the lighting on your scene is complicated, then light-tree should be beneficial.
