Is there a way to target a specific html popup (in body-end.html) then use the onClose command to change to a specific Camera view, i saw it in action and also it did work on the Shapespark API example, but its for the popup that loads on scene load.
Displaying HTML pop-ups
To display an HTML pop-up use the following function:
Viewer.openPopup(content, options, onClose) - opens a pop-up with content defined by an HTML markup string in the content argument. options is an optional object definining how the pop-up is laid out and
onClose is an optional callback called when the pop-up is closed.
Thank you
