The movement is too slow
Hi
My project files are not too heavy. SU model is nearly 100MB and Shapespark working file is around 260MB but the movement of the tour is too slow compared with other projects that are much more heavy. What impacts the speed of movement? How can I improve it?
If this is just a matter of the camera speed, you can increase the speed in the Camera tab.
But if this is too low frame rate, the reason that we see most often is too high number of objects or too complex geometry. If you could share a link to your scene we should be able to check what causes low frame rate in this case.
