We want to show some information categories. For this it would very helpful to set a triggergroup which is visible or invisible only in defined views like the object dependence on views. For example all yello trigger, that shows all general informations of a machine or room and all green triggers shows some special features of a machine or room. A seperation of trigger groups would be very cool too
This is possible with Object type triggers. Such a trigger doesn’t add a sphere/sprite to the scene, but is tied to an existing scene object imported from the 3D tool. If you use such custom triggers, you will be able to configure their visibility depending on the view using the Custom hide in views setting.
Thx this sounds good, will try it that way. This 3d objects could also rotate to camera
