http://demo.unified-streaming.com/video/tears-of-steel/tears-of-steel.ism/.m3u8
I used this url, format HLS but it cannot play on shapespark
Could u able to show me the detail plz?
Link work now. But one question, can i input livestream link?
Hi @_EG_Hi_n_Nguy_n. After replacing āhttpā with āhttpsā in url address, stream should start to play.
What if I canāt produce https? Only http? It wonāt work any way around?
Due to browser limitation there is no any workaround.
Hi Ville,
I have a potential project that will require live streaming and will be testing out soon. Can you please share any tips or tricks or specific settings to make this work? I would love to email you directly with some more specific questions and hopefully you can guide me through.
Thank you in advance,
.m3u8 ending is the only way to stream?
.m3u8 at the end of the URL is not required, but the URL needs to point to a HLS stream.
Ok⦠Thanks a lot. Iāll try to learn more about.
Certainly! Configuring a live video stream using HLS (HTTP Live Streaming) typically involves several steps, and the exact process can vary depending on the platform or service youāre using. Below is a generalized guide for setting up an HLS live video stream. For the purpose of this tutorial, Iāll provide instructions for setting up an HLS stream using popular streaming software OBS Studio and assuming you have a hosting service that supports HLS, like Dacast, VPlayed, and more.
Prerequisites:
- OBS Studio Installed:
- Download and install OBS Studio.
- Dacast Account (or Similar Service):
- Sign up for an account on Dacast or any other streaming service that supports HLS.
Steps:
1. Configure OBS Studio:
- Open OBS Studio and go to āSettings.ā
- Under āStream,ā select the streaming service youāre using (e.g., Dacast, VPlayed, muvi and more).
- Enter the stream key provided by your streaming service.
- Click āOKā to save the settings.
2. Set Up Video and Audio Sources:
- In OBS Studio, add your video and audio sources (webcam, microphone, etc.) to the scene.
3. Configure Output Settings:
- In OBS Studio settings, navigate to the āOutputā tab.
- Set the Output Mode to āAdvanced.ā
- Under āStreaming,ā choose the desired streaming service (e.g., Dacast) and set the bitrate based on your internet connection and streaming platform requirements.
4. Configure Video Settings:
- In OBS Studio settings, go to the āVideoā tab.
- Set the Base (Canvas) and Output (Scaled) resolutions based on your preferences and streaming platform requirements.
5. Start the Stream:
- Go back to the OBS Studio main screen.
- Click āStart Streamingā to initiate the live stream.
6. Check Streaming Service Dashboard:
- Access your Dacast account or the streaming service youāre using.
- Verify that the stream is receiving data and is marked as live.
7. View HLS Stream:
- Your streaming service should provide an HLS URL. This is the URL you can share for viewers to access your live stream.
- Test the HLS stream on different devices and browsers to ensure compatibility.
hello, today we use stream fonction perfectly with the build in tool from shapespark
but can i control it directly from javascript and body-end ?
I am sorry. This is not possible. We have plans for extending the viewer API so the extensions could be interacted with programmatically, but we donāt have an ETA for it yet.
