Hi, how can I make a welcome banner like this?
Thank u so much
You could leverage the HTML pop-up API: GitHub - shapespark/shapespark-viewer-api: JavaScript API for interacting with the Shapespark 3D scene. or tune the custom image banner example from: GitHub - shapespark/shapespark-viewer-api: JavaScript API for interacting with the Shapespark 3D scene..
I donât see the welcome banner but only this
@wojtek
Could you share a link to the uploaded scene, so we could take a look?
https://rgg.shapespark.com/secolo025bis/
thank u @wojtek !!
Did you manage to solve it? The banner at https://rgg.shapespark.com/secolo025bis/ seem to be working now.
Yes @jan but I would like to add a click in order to close the banner, and right after start the autoplay. Is it possible?
Thank u so much!
Yes, in the Shapespark editor viewer tab disable the âStart on scene loadâ checbox for the auto tour and replace the last part of your body-end.html with the following code:
<script>
// After the banner is clicked start autotour and fade out the banner by
// using a css tranisition.
function bannerClicked() {
document.getElementById('banner').classList.add('fadeout');
document.getElementById('tour-button').click();
function addBannerClickHandler() {
document.getElementById('banner').addEventListener('click', bannerClicked);
// WALK.getExtraAssetUrl can be called only after document is
// loaded.
window.addEventListener('load', function() {
var bannerElement = document.getElementById('banner-img');
bannerElement.src = WALK.getExtraAssetUrl('banner.jpg');
viewer.onSceneReadyToDisplay(addBannerClickHandler);
</script>
thank u so much @jan !!!
How can i have the banner in the center of all screens (without fullscreen, fullscreen, ios, androidâŚ)?
@jan
Hi @pierugg8 !
You can try one of these two methods, both should work equally well. However if you find any issues, let me know please.
#banner
and #banner-img
to:#banner {
position: absolute;
top: 0;
width: 100%;
height: 100%;
z-index: 10;
display: flex;
flex-direction: row;
align-items: center;
#banner-img {
margin: auto;
max-width: 100%;
max-height: 100%;
#banner-img
, (then #banner
does not need any styling), and change hide-banner
function to target #banner-img
to avoid flickering :#banner-img {
z-index: 10;
position: absolute;
top: 50%;
left: 50%;
transform: translate(-50%, -50%);
max-width: 100%;
max-height: 100%;
function hideBanner() {
document.getElementById('banner-img').classList.add('fadeout')
I tried the first one and it works.
Thank u so much @kamil!
