Hi.
I have a question. When I export a scene to Shapespark it seems that the object pivot is set to the world 0,0,0 coordinates. Can this be avoided?
Tim
Hi.
Tim
Shapespark uses world coordinates under the hood for non-instanced geometries, however it should be transparent to the user. In what way does the (0, 0, 0) pivot point occur to you?
I need it right at the corner of a single object. But for 5 individual objects.
The pivot point is not configurable in Shapespark. Could you describe what you are trying to achieve in more details - perhaps there is some another approach that could help here?
We want to rotate an object around its individual set y axis by custom programming
I see. So, unfortunately, this isn’t possible through the API, because as you write, the pivot point is not what you expect. Using the built-in Y to camera option isn’t an option for you, is it?
No, this will, unfortunately, not lead to the desired result.
Thank you
