I have a client that is looking to put together a trade event that would have 1,500 booth locations in it, these booths would all have a TV with a pitch video playing on them.
Is it possible to have these videos linking from Youtube, as downloading 1,500 videos when the tour loads would make this a really bad user experience.
Hi, YouTube videoâs canât be used as WebGL texture because YouTube doesnât expose HTML Video elements for them. What could be done, is to place the videos on some external server and use JavaScript API to load them only when the user clicks on a screen or some other trigger.
Iâm not 100% sure if browsers will download anything if you configure the videos not play automatically on the scene load. Videos for WebGL are streamed, so if all of them will be paused it is likely that browsers wonât be downloading anything.
But Iâm afraid that with 1500 booths you will run into performance and memory problems. You will need to have at least 1500 separate materials rendered in a render loop(usually scenes have less than 200), geometry and lightmaps will likely be large. 1500 booths will likely be above Shapespark capabilities.
@jan This Javascript API can place the videos directly in a surface inside shapespark or ina a window or frame outside the tour?
This Javascript API is the same like we use for mini maps?
This is interesting. I tried testing the example code and it works great. But how do I put it behind a trigger? I tried via extensions - script and setting up a trigger but nothing happens when I click it.
What Iâm actually looking for is having extensions for all 40 or so screens on the first model whose triggers would start the video from an external source on the screen. So I guess Iâm not rather searching for a âpickerâ but a âplayerâ.
The goal is to achieve less strain on the model using this method.
If youâd like to make certain scene object types act as a trigger for video textures fetched from external sources, then body-end.html seems like the best way to go.
Iâve sketched a sample script showing how to do it in the âexample-roomâ scene. Please make copy the vanilla âexample-roomâ scene from C:\Users\<USER>\AppData\Local\Shapespark\app-<VER>\resources\ under a different name in the Document\Shapespark directory, and add the following body-end.html file:
<script>
viewer.setMaterialEditable('Curtain fabric');
viewer.setMaterialEditable('Rug');
function createVideoTexture(src, muted, loop) {
const video = document.createElement('video');
video.src = src;
video.autoplay = false;
video.muted = muted;
video.loop = loop;
return viewer.createTextureFromHtmlVideo(video);
function setUpExternalVideoTexture(triggerNodeTypeName, materialName,
videoSrc, muted, loop) {
let videoTexture = null;
viewer.onNodeTypeClicked(triggerNodeTypeName, function() {
// Create the video texture only once.
if (!videoTexture) {
videoTexture = createVideoTexture(videoSrc, muted, loop);
const material = viewer.findMaterial(materialName);
material.baseColorTexture = videoTexture;
if (!videoTexture.isPlaying) {
videoTexture.play();
} else {
videoTexture.pause();
viewer.requestFrame();
return true;
setUpExternalVideoTexture('Rug', 'Rug', 'https://cdn0.shapespark.com/demo/ASSETS/textures/dots-video.mp4', false, true);
setUpExternalVideoTexture('Curtain A', 'Curtain fabric', 'https://cdn0.shapespark.com/demo/ASSETS/textures/lines-video.mp4', false, true);
</script>
When you click the curtains or the rug the original texture will be replaced with a video texture from external source.
That said, Iâd first try to use video textures from the scene, as you write in Triggers, video textures and model accessibility - #3 by ville . I believe paused textures shouldnât consume much memory or computational resources, even after they have been loaded.
No, it is not possible, video textures need to be added from the editor and uploaded as a part of a scene. But you can show YouTube video in a HTML Label popup.
Hi. I was trying out fetching videos from external servers onto the texture. The code mentioned here works well. However, I was wondering if there is any way to add controls (like rewind, forward, seek) apart from the play/stop. This would be very helpful for long videos. Thanks
Not sure itâd work but since itâs a video object, you could try with something like video.currentTime += 5 for the forward (and -5 for rewind ) in a function linked to a button of your own. Even the seek could be done this way (little bit more complicated though âŚ). Let us know if it works
