I’m trying to change the color of an object via a trigger.
Material Picker does not suit me because you have to choose the color.
I am creating an Echop 360 for a client who sells notebooks with different variations; Choice of format (A4, A5…), choice of cover, and finally choice of interior. Of course I want to use 3D to give interaction to the selection and display the right command button but I’m stuck…
This is something that could be implemented using the viewer API but would require custom HTML/JavaScript coding. Unfortunately, we cannot provide you with a complete example (see: About the Customization category), but with regard to our API such a snippet allows you to change the material color:
var material = viewer.findMaterial('<MATERIAL-NAME>');
material.baseColor.setRGB(<R>, <G>, <B>);
material.setUniforms();
viewer.requestFrame();
provided that before the scene is loaded you mark the material as editable:
viewer.setMaterialEditable('<MATERIAL-NAME>');
