Hi Gang!
After baking a scene several times I was trying to figure out why the graphic resolution looks so low. I came across a previous user posting (Materials looks low resolution) and used Shapespark’s solution of #nobasis at the end of my scene address. It worked!
Unfortunately, I think I need a more permanent fix. This is forwarding on to a developer. Is there a way I can eliminate the compression more permanently?
Thanks!
resolution_nobasis|690x300
