We are proud to announce the new release of https://cloud.shapespark.com which allows you to add a custom domain to your account. Thanks to it your scenes can have addresses from your own domain, eg. 3d.your-domain.com/scene-name while still being uploaded in the ordinary way - using the “Upload” button - and served from the Shapespark servers.
It may be a good alternative for self-hosting and gives you more options to customize your visualizations.
This feature requires Plus monthly plan. You can add your domain in the Settings tab and reconfigure your domain by adding a CNAME record with the target: <your-username>.custom.shapespark.com. (the trailing dot is important).
Hi
I’ve just upgraded my plan to Plus
Now I would like to use the custom domain feature but blank page appears when I’m clicking settings tab in the https://cloud.shapespark.com/
Should I enable some additional option ?
I’ve recently tried to get this to work. I’m assuming this applies to previously uploaded scenes… Would I need to reupload the scenes? My projects right now are only appearing under the old domain.
If that wouldn’t work, then if I were to guess, though, I’d try the zone editor. Creating a CNAME there is something that’s possible. You might need to export the zone, manually edit it, and import it to get it working. That’s kind of an advanced workaround, though.
Wordpress staff is also probably willing to help you out.
@John_Burlinson I’ve check it and unfortunately your subdomain isn’t a proper CNAME to our service. It looks like subdomain is already added but as a page with static information… Could you verify your DNS configuration again?
im new here and really dont understand how this works. can you explain please? with the custim domain i wont see the shapespark.com text in the links I share?
