Dúvida sobre animação
Como animar uma porta e uma janela para abrir e fechar?
Shapespark doesn’t support animated objects. You can use Swtich objects extension to toggle objects visibility when a user clicks some trigger, for example a door handle. This allows to switch between open and closed doors by hiding one and showing the other.
Bom Dia! meu amigo, tem como fazer um tutorial explicando e fazendo a animação para abrir as portas? Porque não estou conseguindo achar essa opção.
It is not possible to animate opening the doors, you can only switch between open and closed doors (so states between open and closed doors are not shown). Unfortunately, we don’t have any tutorial with object switching, only this post that explains how to do it: Replacing object extension - #2 by wojtek
