We experimented with a JavaScript API function to listen for hovering over a particular material some time ago. We were thinking of dropping it and looking for a more general solution for emphasizing clickable objects in the scene (including triggers). However, I see the function hasn’t been dropped yet, so I have to back off from my statement that “there is no way do it” (sorry for the confusion, @tim).
To make the mouse cursor change when it hovers over materials MATERIAL-1, MATERIAL-2, …, MATERIAL-n you can add a Script extension with the following code:
const viewer = WALK.getViewer();
function handleHoverChanged(material, hoverActive) {
if (hoverActive) {
document.body.style.cursor = 'pointer';
} else {
document.body.style.cursor = '';
viewer.onMaterialHoverChanged('MATERIAL-1', handleHoverChanged);
viewer.onMaterialHoverChanged('MATERIAL-2', handleHoverChanged);
viewer.onMaterialHoverChanged('MATERIAL-n', handleHoverChanged);
If you have a separate material for each of your trigger, you could extend the handleHoverChanged function to also highlight the material by making it emissive:
if (hoverActive) {
material.emissive = true;
material.emissionStrength = 5;
viewer.requestFrame();
} else {
material.emissive = false;
