good day
how to fix this, there are blue-ish texture appearing when opened in smartphones.
Could you share a link to the scene on which those problems are showing up?
Also, on what model of smartphone are you experiencing those problems?
@Alex99 Can you share a link to the scene on which you are experiencing those issues?
We tried in on Android phone and ipad, same issues.
I tried baking it on highest settings and lower, same results.
We are investigating this issue, but for now I can say that this kind of wrong coloring happens in situations when there are very strong lights or very dark scenes combined with non-standard tone mapping (high contrast can also increase this effect).
For now You could try and decrease the strength of lights in this scene.
Meanwhile we will try to find a fix which will prevent this glitch from happening even with strong lighting.
Best regards,
Krzysztof Jakubowski
Hello,
there is one at E0 02 when you turn right and when when going from E0 to E2 01 on the right but this disappears after the camera transition.
We’ve fixed this issue and will release it soon.
You can check if the fix works for you right now, by adding a following suffix to the URL of the scene:
‘?webwalk=705’. For example:
or:
This issue is fixed in the latest (3.0.3) Shapespark version, so the URL suffix is no longer needed.
