Hello, we are having a problem with some textures in the material picking. After some tests the sofa texture started to get like this (image below). Can someone help us?
This problem occurs when a texture that does not tile in the model is placed by the material picker on an objects that tiles the texture. Please see: Material picker problem - #5 by wojtek for more detailed explanation and a workaround.
Thank you, Jan! I will try to solve it with the other discussion xD
I’ve made it! Thank you, now everything it’s running okay with the textures.
