Black or mixed texture!
I have this issue with texture in my model, what can I need to do to fix it?
https://all360.shapespark.com/cuarto_de_bano/#autoplay
@jorgearq, have you already solved the issue? I don’t see any material picker issue in the scene now. Perhaps, I cannot find the material picker you refer to.
No, I’m not solved it. The problem is located in the shower wall, but in previews tests are in bought walls
OK, I see it now. Could you take a look at this forum post: Material picker problem - #5 by wojtek ? You need to map the alternative textures in SketchUp, so that they are tiled on the material pool element.
